Create a command library subvi
I am making a user interface that runs different tests that involve some motion commands.  The motion commands are simply sending a string command to a DLL file.  Is there a way that I can group all of my motion commands (like move up, move down, stop, pump on, etc...) into one subvi and then call whatever command I need in the main vi?  I hope that makes sense.  Thanks
(3,513 Views)
Accepted by secr1973
Sure there is!   Smiley Very Happy
Oh yeah - you probably want the details...
Well one thing you can do is start with the VI you have now for talking to the device and replace whatever is feeding string to the IO routines now with a case structure. Next, put all the various strings in the case structure (one string per frame, please) and then wire an enum control to the selector node on the case structure. Finally, create an enumeration for each operation (move up, move down, stop, pump on, etc...). Now which ever string you select will be sent to the IO routines.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,504 Views)
"mikeporter" <x@no.email> wrote in message
news:1234307409188-850621@exchange.ni.com...
And make the enum a type def, or you'll have to replace them all if you add
one item!
Wiebe.
(3,484 Views)
