Create a button on the front since the diagram
Yes you understand now Smiley Happy
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 11 of 16
(795 Views)
Slate wrote:
And if I unterstand well, it's the same for an array of buttons !!
No, an array of buttons will work (within reason, dont try to create a million buttons!). Resize the container and write to a local variable of the array to initialze all the extra buttons. What have you tried?
Message 12 of 16
(794 Views)
Accepted by Slate
Here's what I had in mind...
Message 13 of 16
(789 Views)
Yes I unterstand and you have right. It will be a good solution !
Thanks you for this !
So it's impossible to create buttons dinamically in the run mode ? shame ...
Message 14 of 16
(783 Views)
Dear friend,
                      Its not shame. labview needs to know in the before run time from where it is getting inputs. if is not defined then it will be great problem to manage. If somewhere it is expecting some input from control and of haven't created then it will be problem for LV to execute the VI.
Be practical friend as LV is not magician to know all this in advance
--Ranjeet
Message 15 of 16
(778 Views)
You are right I know, I just like to search some new methods when I do something to learn more !!
And I don't know why but I liked this one ! 🙂
Thank you all for your answers !!
Message 16 of 16
(775 Views)
