Create a Graph from 2D Query Array
@Niccolo' wrote:
2)Is it possible to have a Bar graph instead of the normal one?
That is just a simple setting on the graph.  If you click on the plot in the Plot Legend, then go to Common Plots and then choose the bottom left option.  That would be a bar graph.
Message 11 of 14
(1,424 Views)
@Niccolo' wrote:
How can i change the scale of X and Y in the Graph in the front panel? cause now it's hardly impossible to see the Temp values
You can make the graph palette visible and then choose all kinds of zoom options.  Or you can just type in the values you want on the axis itself to zoom in.
Message 12 of 14
(1,421 Views)
But even if a have more than 200 values the graph only shows 2 results. Why?
And the x charts instead that having Date/Time values has strange numeric values.
I attached you those problems.
Thanks so much
Message 13 of 14
(1,415 Views)
Accepted by Niccolo'
You just have a bunch of values that seen to come into 2 packs.
You need to change the format of the x-axis to make is display as Date/Time.  Seriously, go into the properties of the graph and just look around.  You can set all kinds of stuff in there.
Message 14 of 14
(1,402 Views)
