Create/Simulate a running signal from datapoints out of a spreadsheet or Excel File
I would autoindex in a FOR loop for outputting your data.  Then have that inside of a While loop so that you can select which row to output.  Only read the file before the main loop.
Message 11 of 13
(1,147 Views)
Thank you very much crossrulz, I understand the way you did it, its way better then mine :).
The endgoal should be to create a SubVI with one output like a DAQ that acquires data from a running process, so I can just replace my SubVI with the DAQ when integrating the monitoring software into the process. When I create a SubVI of the code it doesn't work anymore. I don't get why. Are there some more steps needed to achieve the painted SubVI?
Message 12 of 13
(1,134 Views)
Well, if you are doing it with a subVI, you should not have the loop.  All the subVI should do is read the file and output the desired row.  That would be the equivalent to a single DAQmx Read.
Message 13 of 13
(1,106 Views)
