Create Installer with Options
I know you can add additional installers when you build an installer for your exe.
But is it possible to have a dialog to select installers? For example, would you like to install the TDM excel add-on, or would you like to install the Win10 GUI etc.
Cheers,
mcduff
(3,962 Views)
Accepted by mcduff
So this isn't possible with NI's installers.  But what I have done in the past is used Inno Setup (using ISTool as a helper) that can make a single installer, that then runs other installers, based on the user's selection.  It works pretty well, but getting the individual installers from NI can be a pain, and knowing what dependencies are on what makes things more difficult.  In the end I usually have multiple installers from NI, and I just run one or another based on user selection, but that of course creates lots of duplicate files, and makes the installer balloon since installers are essentially duplicated.
There isn't a good solution, but there are some solutions.  Since your situation sounds more simple I bet you can get away with it where it runs your main full installer, and then optionally installs the TDMS add on.
(3,954 Views)
Thanks. That's what I thought, but figured it would not hurt to ask anyways.
Cheers,
mcduff
(3,949 Views)
Honestly the Inno Setup stuff isn't bad, and it is free, but there aren't any good LabVIEW focused examples or tutorials.  I know of a few LabVIEW people that use it with great success, but the time invested in learning something new, and troubleshooting is non-trivial.
(3,935 Views)
