Create Function
I have created a VI to Calculate the HI time of my input. now i want to re-use it as a function many times, Can anybody help me out.
Input= Boolean
Output= Time (No of days, Hours)
(2,856 Views)
do you mean, you want to call it as a function/sub vi in other vi's??
(2,849 Views)
Hi M_Atif,
why don't you stick with your old thread?
I made a subvi from your vi. (There's a 'Create SubVi' entry in the Edit menu!).
Please check the subvi, it's not perfect. You will get problems when running this in parallel - making it reentrant may help. You can also change the output to the value/formatting you need. And there is no documentation so far 😉
(2,842 Views)
