Create From Data Type when scripting crashes LabVIEW
When using scripting (LV2010) if I call the Create from Data Type method (available in invoke node when a reference to the BD is wired), if I wire anything but 1 up to the "style" terminal, it crashes LabVIEW. LabVIEW then restarts with a error saying that "The last time you ran LabVIEW an internal error or crash occured at lvmain.cpp, line 1756". If I wire 1 however, it creates a constant fine.
I see in the context help that it always creates a control initially but it seems I can only get it to create a constant. So then I decided ok, work around, create the constant, take the new object refnum it returns and from there change the constant into a control...but I can't get this to work either. Can someone point me in the correct direction? Here is the code and screenshot; it's a quickdrop plugin.
it is meant to execute on a cluster that is being viewed as an icon if you want to test it you will need to create that.
I submitted it with the "style" value set to 0 so if you don't want LabVIEW to crash, set it to 1.
(4,405 Views)
Accepted by topic author GregFreeman
No time for in-depth exploration now.  Create from Datatype also killed my LV10.  What I was able to do after creating a cluster constant, viewing it as icon and selecting it.  (1) With scripting, create a New VI and paste the constant to the diagram (2) Cast the pasted objected to ClusterConstant and Change to Control.
I think I know where you are heading, should be interesting.
(4,384 Views)
hint * idea exchange
(4,376 Views)
A workaround to your issue is to use the Change To Control method on the new constant you just created using Style = 1.  I have submitted CAR#247236 on the issue to R&D.  Good luck.
(4,340 Views)
