Create Different Instances of a Class
Gotcha warning!
Do not make the template part of the class. It MAY work in the development environment but in an exe LV does NOT concider the clone a member of the class so all private and protected methods can not be used.
Been there done that.
Ben
Message 11 of 14
(1,314 Views)
@Ben wrote:
If I understand you correctly yes a method will act on the Class instance in the wire it is passed. Provided the class instances are unique.
Hi Ben
I have the following situation. I have a Graph Class consisting of a method with Graph Display as one method. I have a button(s) which when clicked will Create an instance of the class and Call the Graph Display method. Now, when i first click the button, the Graph Display launches. But when i Click on the button again it throws an error saying the "The VI is not in a state compatible with this operation."
I have attached an example of the same. In the example, i have created two static instances of the Graph Class. I have two buttons in the Front Panel each launching a different instance in a event structure.
Thanks and Regards
Suneel
Message 12 of 14
(1,305 Views)
Did that link to my image library not work for you?
The last image in the series I posted for you is shown below but larger.
If you look at where I have included the comment "Open a re-entrant clone to use as an instance of the specified object" you will see I am using a switch to load the instance as re-entrant.
From the error message you reported I suspect the first instance is not being loaded and run as re-entrant so when you attempt to run load the second instance it opens a ref to the the first (after all it is NOT re-entrant) and an attempt to run an already running VI is a "right out".
If you want to get a better idea of the mind-blowing factors involved in re-entrancy and a simple example that was discussed at length by the community then please review my Nugget on Using Occurences that can be found here. It includes a zip of the code used in that Nugget and the topic of re-entrancy what beat to death.
BTW: I don't think LVOOP is your issue here. Using LVOOPish words in your question is limiting the potential number of readers/responders.
I hope that helps,
Ben
Message 13 of 14
(1,299 Views)
Hi Ben
I got, it worked. I had missed the reentrant option setting while calling the vi dynamically.
Thanks and Regards
Suneel
Message 14 of 14
(1,295 Views)
