Crash on Performance and memory check for large applications
Hello all,
I have a fairly large LabVIEW (~500 sub VIs). I am trying to carry out a timing analysis of the whole application. I tried this by enabling the "Timing Statistics" and "Timing Details" on the LabVIEW front panel -> Profiles -> Performance & Memory. When I press on Start, the entire LabVIEW application crashes. I haven't noticed a spike on CPU usage. I repeated the same method on one of the smaller sub VIs and it seems to work fine. Unfortunately, due to IP issues, I can't share it here. Has someone run into similar issues or have potential workarounds?
-Ram.
(3,236 Views)
500 VIs really isn't that large, can you perhaps break it into pieces and test them separately?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,222 Views)
Which version of LV?
THere was a bug that would crash LV when using the profiling tool on apps with .... ? The DB Toolkit ? .....I think.
Ben
(3,199 Views)
Adding to my previous...
The LV 8.2 bug-fix list
and the
LV 8.51 bug-fix list
have an umber of listing for crashes when using the profile tool.
Ben
(3,189 Views)
Thanks for the suggestions to dig deeper in my application and to refer to http://digital.ni.com/public.nsf/allkb/CAB9E23506CA6A18862572B8001066C6. I found that the VI causing the problem was writing a LabVIEW measurement file. Removing it fixed the problem. This is not entirely captured by the following fix. I have attached the VI incase someone is interested.
45MB5LFNFixed an issue where LabVIEW hangs when you close the configuration dialog box of the Get Properties Express VI, the Set Properties Express VI, or the Write To Measurement File Express VI.
-Ram.
(3,165 Views)
