Counting Edges
I am trying to read the rising edges from my encoder.
It doesnt work and I would like to know if my VI program is supposed to work. (attachments)
Thank you,
Jack
(3,096 Views)
Hi Jack,
LabVIEW ships with some great DAQmx examples.  I would recommend checking out the counter examples.  In LabVIEW, select Help >> Find Examples.  Once the NI Example Finder has launched, navigate to Hardware Input and Output >> DAQmx >> Counter Measurements.
Hopefully this gets you on the right track!
Kevin H
WSN/Wireless DAQ Product Support Engineer
(3,060 Views)
Thank you very much,
I just found my problem. The program was good but there was a false contact. When I was putting my Voltmeter on the screw, the contact was good and I was seeing 5V. But when I was getting it out, it was going to 0V !
Thank you,
Jack
(3,058 Views)
