Count Boolean Buttons in Cluster to Array
I am trying to figure out how to have an array output showing which button is pressed depending on what buttons are pushed in a cluster of boolean buttons.
Basically if the first button is pressed, then the output array would have a value of 1.  If the first button is pressed and the 9th and 10th button is pressed, then the output array would be 1, 9, and 10...so on an so forth.
I attached my .VI with the cluster of buttons that output into an array that shows the boolean value (1 or 0)....but this isn't quite what I am wanting to do.
Any suggestions would be appreciated.
(4,209 Views)
Autoindex through your boolean array. When true append index to output array.
Lynn
(4,207 Views)
Accepted by MCHammer
Something like this?
(4,202 Views)
Stupid question...what is the item I circled in red?  I looked through the menus and could not recreate it.
(4,190 Views)
It is an empty array of I32 integers, or in other words an array constant.
The following link tells you how to make one.
https://www.ni.com/docs/en-US/bundle/labview/page/creating-array-constants.html
Cheers
(4,181 Views)
Thanks guys.  That's exactly what I was looking for.
(4,177 Views)
Or, after wiring up the inside of the loop, simply right-click the left shift register and select "create constant". 😄
(4,167 Views)
