Could I use ni6723 to generate square signal?
I just want to use the AO port of NI6723 to generate square signal with frequency between 10kHz to 500khz. The duty cycle should be 50%. The maximum voltage will be 10V and I want to change the minmium voltage between 0V to 5V.Is that possible?Could you give me an example?Thanks a lot!
Best regards!
Ciyuan Qiu
(2,450 Views)
For generating periodic waveform, you can look for Regeneration mode. Topic like Glitching might be of interest to you.
Try below example.
DAQmx AO Regeneration - Dynamically Updating User Buffer Data
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(2,426 Views)
