Corrupted TDMS File
Hi JW-L3CE,
I'd like very much to supply the help. The 3.2 GB TDMS file is huge and I believe the data in such a huge TDMS file is valuable for you. Did you try to delete the .tdms_index file and then open the .tdms file again?
If it still doesn't work, now, the problem is how we can find a way to send the file from you to us for investigation and recovery. I'm not very sure whether the FTP sever of ni.com can hold this file, but please have a try:
1. Please zip your .tdms file and .tdms_index
2. Upload to ftp://ftp.ni.com/incoming
3. Reply here the name of your file
Please let me know if there's any problem if you can not upload the file. We can find out some other ways of I can contact our IT for help.
Yongqing Ye,
NI R&D
Message 11 of 35
(3,516 Views)
@YongqingYe wrote:
Hi JW-L3CE,
Yongqing Ye,
NI R&D
I can't seem to log in anonymously, or with my forum e-mail/password.
(using FireFTP within Invincea and logging into the link you provided)
Josh
Software is never really finished, it's just an acceptable level of broken
Message 12 of 35
(3,509 Views)
It is possible that the FTP client softeware is configured to use Active FTP instead of Passive FTP.
Message 13 of 35
(3,500 Views)
It's checked as passive.
Josh
Message 14 of 35
(3,496 Views)
OK. Could you please use Internet Explorer to open ftp.ni.com/incoming? And the page contains some instructions of how to use it.
And, maybe you can also try SmartFTP, http://www.smartftp.com/, I just tried it and it worked to connect to the FTP server.
Message 15 of 35
(3,492 Views)
I, unfortunately, don't have that luxury. We have this lovely software called Invincea which is a virtual machine and every other communication outside is blocked. So I'm stuck with firefox which can browse the ftp link, and FireFTP.
What login an I suppose to be using?
Josh
Message 16 of 35
(3,491 Views)
Anonymous is enough. Either Internet Explorer or SmartFTP (just goole it and download for free) should work. I tried it and I saw some big files there. Maybe a single 3.2 GB file cannot work, but some compression tool maybe can split the file into multiple smaller files and this can help us to receive the file from you.
Message 17 of 35
(3,489 Views)
I tried. My company blocks any communications that don't originate from this software. SmartFTP and Internet Explorer simpy cannot get through.
It's not the file size. I can't even connect to the FTP server using FireFTP (which I'm stuck with)
Maybe I'll take it to an outside location. Funny how these crazy internet protection methods just force you to circumvent the system.
Josh
Message 18 of 35
(3,484 Views)
OK, no problem.
Thank you for your patience and please reply here and let me know when you complete uploading the file.
Message 19 of 35
(3,482 Views)
Ok, I apologize. Our IT policies are rediculous. I'm still working on getting this file to you.
In the meantime, I figured out the the TDMS recovery VI above fixed the offset value. To this effect, I created the attached VI that checks all of the offset values. It works by incrementing through each TDMS segment using the offset value. if it doesn't find "TDSm" at the next position, it flags an error. My corrupted TDMS file passed. Not an offset problem. However, this doesn't check the data offset (a bit more difficult)
I also checked the first and last segment by appending them. The first appears to be metadata for the entire run. Appending them created a small TDMS file that contained 20 points. It opened fine.
My next step might be breaking this file into pieces.
Josh
Message 20 of 35
(3,445 Views)
