Core 1, exercise 3-1 question
I'm new to LabVIEW.  Doing the Core 1 course online.
Exercise 3-1 calls for an NI Instrument Simulator to simulate communication with an instrument over GPIB.
However, I don't have one of those.
Is there a way to complete the exercise without it?
(1,415 Views)
It only calls for a simulator if you don't have a real instrument. It specifies GPIB as it requires less setup than RS232 or other protocols as the setup is in the H/W.
Do you have access to any GPIB instruments (easiest) or RS232 instruments?
if not you can probably purchase a really simple RS232 thermometer from somewhere online for £20 or less.
like this:
TM: RS232 thermometer | Papouch.com
James
CLD; LabVIEW since 8.0, Currently have LabVIEW 2015 SP1, 2018SP1 & 2020 installed
(1,396 Views)
Thanks James.  We have some mass flow meters with RS232 connectors.
I'll try using one of those.
Mike
(1,373 Views)
