Copy images from ringbuffer into ram
I changed the "Acquire every Image (Optimized Performance).vi" example in 2 ways. Overwrite Mode: Fail and I create an array from an extracted image in order to save it in ram. I get crazy low processing rate of under 4 per second. I am running this on a 4 GHz Xeon and 128gb ram machine.
Am I doing something completely wrong?
CLA
(1,475 Views)
you probably have to re-work this section
feed the initialized 3d array in a shift register instead of a tunnel and use "index array"+"replace array subset" or alternatively use the for loop's auto-indexing on the the blue 2d array inside the loop instead of feeding the 2d array into "insert into array".
(1,455 Views)
I changed the tunnels to shift register, now it works.
CLA
(1,412 Views)
