Copy and Paste within an Executable
I would like to be able to copy information (using cntl + V) from a text result in my executable VI. Attached is the VI (password VDI) and some screen shots of what I want to do. How do I do this?
Gerhard
NI Software :  LabVIEW  version 8.2
NI Hardware :  Select one if your issue is related to hardware device
Driver Version :
OS :  Windows XP
Customer Information :
Gerhard Schoenthal
Virginia Diodes, Inc.
(3,273 Views)
HI,
Why don't you use multicolumn listbox instead of table? You will be able to select a cell and copy data from shortcut menu.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(3,253 Views)
Accepted by gschoenthal
Try to set the "Headers Editable" in the right click menu
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,246 Views)
Coq Rouge,
Thanks. That solution worked perfectly.
Gerhard
(3,200 Views)
