Converting time string to integer (****) in Labview 5.1
So i'm very new to labview, learning as i go, but as the title says, i need to convert a time string to an ineger so that it can be placed in an integer array which will be compiled then writen to file at a specified end ( by user ) I just want 4 digits **** to indicate military time. And unfortuanly i'm stuck with labview 5.1. Any help would be greatly appreciated.
(2,822 Views)
I believe the diagram I have attached may have been possible in LV 5.1.
Try to wire this up and see if it works.
The icons may have changed a little between LV 5.1 and 6.1.
Ben
Message Edited by Ben on 10-15-2005 02:49 PM
(2,809 Views)
