Converting measurement in current to other units in LabVIEW NXG
Please I have a challenge on how to convert unit in current to other units such as pH, psi, uS, and gpm in LabVIEW NXG. Please how can I go about it.
(3,754 Views)
NXG has no built-in unit conversions.  You'll either have to make your own, use regular LabVIEW which does have unit conversions, or find a 3rd-party library (probably in .NET, like this one) to create a NXG wrapper for.
(3,716 Views)
Hi ola,
It doesn't make sense (in physics) to convert from current (Ampere) to pressure (psi), resistance/conductivity (µS), flow (gpm), or pH value.
It only makes sense in a "electrical measurement" way - after you read the datasheets of your sensors and apply the equations given there to your DAQ readings…
Do you have problems to apply simple math equations on your DAQ readings?
(3,699 Views)
Thank you for your responses. Let me clarify the unit conversion needed. I have sensors (pH, electric conductivity and pressure) with output of 4-20mA  on my LabVIEW NXG. I want to know how to have my output display in the appropriate units (pH, uS/cm and psi) respectively.
From the manual of the sensors, I have the relationships between the current  output and the appropriate unit. E.g, 4-20mA corresponds to 0-50psi for pressure. I can interpolate and convert current to pressure easily after obtaining results from LabVIEW NXG But rather, I want to know how I can have the appropriate units displayed during measurements with the sensors on LabVIEW NXG. May be how to achieve this with GVI. A video link or detailed explanation will be helpful. Thank you in anticipation.
(3,690 Views)
You do the conversion in you LabVIEW code!
You read from the device, you have a number that represents mA.  You subtract 4.  Divide by 16.  Multiply by your scale factor of 50.  Now you have a value that represents the real world psi.    Use that number in all further calculations.
I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
Learn LabVIEW
(3,680 Views)
Thank you so much for your response. Please, how do I go about the LabVIEW code you mentioned with LabVIEW NXG 1.0.
(3,673 Views)
Seriously, go take the tutorials.  This is VERY basic to put down the math functions and add constants.
GCentral
(3,670 Views)
