Converting decimal string with comma seperator to decimal
I am reading in a file as a spreadsheet string and am having problems with numbers such as 1,450.  When I convert this from spreadsheet string, seperating by tab delimination, to decimal I end up with the number 1.  Any idea on how to make the conversion see that 1,450 should convert to 1450?
Cheers
(3,435 Views)
So the comma seperator is a thousand seperator?
If so  use the following format string: '%.;%f'  (there's a . (dot) between the % and the ;))
IMHO every piece of software that store data witha a thousand seperator should be send to the eternal realms of floppy disks and be magnetized
Ton
My LabVIEW Ideas
(3,425 Views)
I don't understand the solution given above, because it does not work for me.
Sure %.; will switch the decimal seperator to period, this still does not mean that it will skip over the "," when reading 1,450. It will still read only the 1 because anything that is not part of a decimal string will terminate the number field.
I would just do a global replace of all commas with nothing and then convert to an array. (LV 8.0). Now %f will work just fine.
(3,403 Views)
