Converting a 1D-Array of Cluster (Time + Data) into 2D-Array of Time & Data. How?
is there a simple way to convert a large 1D-Array of Cluster (Containing one Timestamp and one Data) into a 2D-Array with Timestamp and Data?
I could index the array in a while loop, unbundle each element and put the timestamps and the data into a new array.
The format of the new array could be an array of double (then the timestamp needs to be converted to double) or an array of strings.
Could I do that without a loop?
Johannes
LabVIEW 7.1 (!)
Message Edited by johanneshoer on 10-15-2009 07:01 AM
Greetings Johannes
Using LabVIEW 7.1 and 2009 recently
(3,100 Views)
Here is a VI. It works, but is there no easier way?
LabvIEW 7.1
Greetings Johannes
(3,096 Views)
Accepted by topic author johanneshoer
Hello Johannes,
if it's possible to handle your time stamps as dbl-floats, I would suggest to use a simple for loop and the cluster to array function (Cluster_to_Array_Mod1.vi).
If you want to stay with the time stamp data type, again use a for-loop, an unbundle cluster and build array function (cluster_to_array_Mod2.vi).
Thomas
(3,091 Views)
