Convert string to timestamp
I want to store calibration dates in a file so they can be checked to the current date and notify the user if any of the equipment is out of calibration.
What would be the easiest way to accomplish this?
Using scan fomr string I have been able to change the date string (MM/DD/YY) to numbers, but how do I turn them into a timestamp?
=== Engineer Ambiguously ===
Message 1 of 24
(31,597 Views)
Accepted by topic author RTSLVU
Look here (if you have hours, minutes, and seconds along with a date):
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHbRCAW&l=en-US
Message 2 of 24
(31,588 Views)
Check out the documentation on the Format DateTime String function. You can format a string to and from a timestamp datatype using %<>T or %<>t
Eric, that cluster manipulation is overkill just to go from string to timestamp and back.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
Message 3 of 24
(31,586 Views)
I'd really recommend you use the ISO standard for time.  You can use the Scan From String, and Format Into String to go to and from a timestamp.
https://lavag.org/topic/15034-timestamp-support-for-format-into-string-scan-variant-from-string-stri...
Message 4 of 24
(31,579 Views)
From Hooovahh's link, this is what you want:
Cheers
Message 5 of 24
(31,569 Views)
James - I've always used that function to do conversions (only because I didn't know better). I learned something today, plus it's probably WAY faster.
Message 6 of 24
(31,559 Views)
This seems like a simpler solution.
Message 7 of 24
(31,516 Views)
It's not a simpler solution... It may be an easier solution to understand because it breaks everything down in to a cluster of info, but the overhead (and space) taken up by that is much larger. You should really get comfortable with string formatting and conversion using the single string scan VIs from the other posts above.
Cheers
Message 8 of 24
(31,507 Views)
I don't understand the other proposed sultions at all and can not figure out how to apply them to my situation.
I can not even figure out how to get your snippet into a block diagram without it just being a picture.
Message 9 of 24
(31,483 Views)
It literally is two primatives and a string constant.  Here is the VI.
Message 10 of 24
(31,431 Views)
