Convert string data to image data.
I don't know how save .txt in "Backslash (\) Codes" format. When I use "Write to Text File Function", I get following - test.
With the help of a copy-paste got - test1.
Message 11 of 20
(6,308 Views)
Accepted by topic author Alexdmk
As predicted 🙂 Write to Binary File is all you need!
Unfortunately I had to use an online converter from BMP to JPG because BMP isn't a format accepted by this forum, but the code still works.
The VI is saved in 2017, the snippet is saved using the LAVA tool to 2013.
GCentralI'm attending the GLA Summit!
Message 12 of 20
(6,293 Views)
Thank you so much. You all really helped me! Smiley Happy
Message 13 of 20
(6,276 Views)
Here is a vi that do bitmap string to image conversion:
https://lavag.org/files/file/304-convert-string-to-bitmapvi/
Message 14 of 20
(6,244 Views)
I have similar issue but in my case only half image is showing.
anyone has a idea what is going wrong here?
Kuddo welcomed
CLAD-CTD
Message 15 of 20
(6,229 Views)
This seems to be a PNG- file. What has happened?
Greets, Dave
Message 16 of 20
(6,229 Views)
Hi Gab,
1. You attached a file with a suffix "JPG", which is a "PNG" instead.
2. That PNG is all black for me. (It's rather small with just 2kB for 640×520 pixel.)
Wild guess:
3. You didn't read the whole image from your device, but just the first half.
Message 17 of 20
(6,229 Views)
Yes, my favourite picture viewer "IrfanView" showed me a black picture too (even after confirming the converting-question), but the TotalCommander- Viewer showed me this:
And this is not half of the picture...
Greets, Dave
Message 18 of 20
(6,224 Views)
Thanks for reply. yes, I am missing some bytes from device but now working complete image
Thanks.
Kuddo welcomed
CLAD-CTD
Message 19 of 20
(6,216 Views)
Thanks.
Kuddo welcomed
CLAD-CTD
Message 20 of 20
(6,216 Views)
