‎06-23-2015 10:02 AM
I've got a controller for a biological system that updates every n minutes or every 2n minutes, depending on certain conditions. My implementation has a timing controller that computes whether or not the current iteration is n or 2n, and feeds the output of that computation into a "Timing" VI in my while loop. As I understand it, this is akin to issuing a sleep() command in a C-like language, and must be avoided. I'm refactoring my code, and I've heard they're well suited for this kind of stuff. Here's how it should work:
This sounds to me like it's kind of a real-time system, although as long as we're within 1 minute of the original deadline, nothing bad will happen.
What would the consumer-producer loop look like? Assume the Timing controller and Main controller are separate VI's.
‎06-23-2015 10:14 AM
It is not apparent that the Producer/Consumer architecture would be any advantage for you. It seems to me that a simple state machine should be adequate. One state implements the timing controller. The main controller is in another state or possibly several states, depending on its complexity. The main timing function would be in a Wait or Idle state. That state would wait about 100 ms and then compare the current time to T+u. If greater, then reset T and go to the main contrller state. Otherwise retturn to the Wait state again. You probably also need an Initialization state, an error handling state, and a Shutdown state.
Lynn
‎06-23-2015 10:35 AM
- Loop begins at time T, T is recorded.
- Timing controller runs, and computes whether loop will get n minutes or 2n minutes. This controller will take some number of milliseconds to complete, so we are no longer at time T.
- Now that the update interval (n or 2n, let's call it u) is known, the loop has until T+u to complete.
- The main controller is run, it takes some number of milliseconds to run.
- The remainder of the time until the next loop iteration should yield the CPU to other processes.
One of the significant things about LabVIEW (in addition to Data Flow and the ability to execute code in parallel) is the importance of Time as a primary data type. There are certain Time-related questions that arise from the scenario you outline which make it difficult to suggest an algorithm.
Hmm, that may be the only question that I have. Let me assume that you can compute the time between calls to the Main Controller some fixed time (say 10 seconds) before calling the Main Controller. If so, here's one way to proceed:
Note that we never need to actually record the Starting Time (though we can) and never use it. The Producer has two sequential Waits of BT-10 and 10, for a total of BT (Between Time), exactly what you want. Because the Waits take place in parallel with the computation in the Frame, this effectively means the computation is done and then the remaining Wait takes place -- the amount of time the computation takes does not matter as long as the Wait is longer than this time. Finally, the Consumer will do one "Control" operation and then wait, getting the next "Go" command when the Producer's Between Time finishes and it starts the next loop.
‎06-23-2015 10:46 AM
Is this really how it works?! That's awesome! So as long as I use the Timing literal, this is the behavior? To clarify your question:
The main controller AND the Time controller depend on the most current sensor value, which is obtained in the same while loop from a Sensor VI. This value is then passed via a cluster into both the Timing Controller and the Main Controller, so they may do their respective computations. I thought this was an okay way to handle it, as the Sensor VI is event-based, so it will not output a value to the cluster until the value has changed from the previous loop iteration. I have run this controller, and it works just as expected in its setup, but I'm always looking to improve its internal structure. Race conditions like these make my head spin sometimes, so any guidance is very helpful!
‎06-23-2015 11:30 AM
To answer your question, yes, this is really how it works. Without seeing the code, I admit to being confused about how the Controllers really work, and how their timing is determined, but I'm going to assume you have this now well under control.
BS
‎06-23-2015 11:32 AM
P.S. -- among other things, I'm a Dues-paying member of the MAA ...
BS
‎06-23-2015 11:47 AM - edited ‎06-23-2015 11:47 AM
As am I, if you couldn't tell 🙂 Here are two screenshots that give a little more detail. The second image is the inside of "ALL CTRL'R"
‎06-23-2015 11:55 AM
It looks like a state machine would do nicely. One loop with everything inside.
Generally wiring False to the stop terminal of a while loop is not a good idea. Forcing the program to stop by hitting the Abort button can leave the hardware in an unknown state, files open, and so on. Either calculate the end of the operation or include a Stop button or an Application Close event so that you can shut everything down in an orderly manner.
Lynn
‎06-23-2015 11:57 AM
I actually had an event-driven stop button built in, but it was causing problems as it would hang the program from moving on. The Timeout couldn't be too low, or you'd never register an event, and it couldn't be -1 as it would never move to the next iteration. If you've got advice for how to handle that, I'd love to hear it!
‎06-23-2015 12:09 PM
ijustlovemath wrote:The Timeout couldn't be too low, or you'd never register an event,
Where did you hear that?
Events will always register. You can make your timeout 0 on an event structure. Any code inside the timeout case would immediately execute assuming that no other event has already happened.
