Convert from 8.0 to 7.1?
Hi Mila!
Ravens Fan is correct.  You can reinstall LV 8.6 without "wasting" a license.  As far as the order of installation, you can install LV 7.1, while LV 8.6 is installed.  However, do not install the drivers that come with LV 7.1. Instead, repair the drivers for LV 8.6.  I hope this helps!
Kristen H.
Message 11 of 14
(889 Views)
I had 7.1 installed on my computer and then installed 8.2 in another folder.
Both work OK but they don't run well together since I think they may use each others drivers by accident.. Also I reset the computer before switching between them.
Regards MArtin
Message 12 of 14
(827 Views)
Hi Kristen
If I have both 7.1 and 8.5 installed on my computer, how can I convert a .vi from 8.5 to 7.1??
Keep up the good work.
Regards
MArtin
Message 13 of 14
(823 Views)
You can't. The only version of LabVIEW that can save to 7.1 is 8.0.
Message 14 of 14
(821 Views)
