accessing shared variables from two PC's on same network
Hello
We have developed application in LabVIEW 8.6.1 for testing mechanical equipments using cRIO 9074 (Real Time controller).
In this application we have used shared variables (Network published) for communications between Real Time controller and Host PC. All shared variables are deployed on Host PC.
Now we want to access the same application(Host PC application) from Tablet PC through wi-fi connectivity.
We have created two seperate .exe to run the application on Host PC and Tablet PC.Shrared variable response for Host PC .exe with RT controller is good,but when we run Tablet PC .exe then response is sluggish(slow).
In this case we create shared variables on Host PC (Network published) and tying to access it from Host PC and Tablet PC.
In our application,
1)Both Host and Tablet PC operate on Windows XP.
2)Programs on Host and Tablet PC are identical.
3)Both PC's are on same subnet.
Please provide appropriate help on this issue.
Thanks in advance....
Sachin
(2,723 Views)
(2,697 Views)
