Convert double to byte array...
> Thanks so much. It worked perfectly. I have another section where I
> have to do the same thing, but the integer is a 48-bit TWO'S
> COMPLEMENT number now. I can't just divide by 256 anymore...but have
> to worry about negation and stuff. Can LabVIEW help w/ anything like
> this? Thanks.
You will need some test cases, but I think that treating the 48 bit
number as a signed 16 bit and an unsigned 32 bit number will be
equivalent -- assuming that you handle reassembling them according to
endianness.
Greg McKaskle
Message 11 of 17
(4,457 Views)
Hi...sorry, could you do me a favor? Could you save your VI in LabVIEW 6.0 format? Sorry...I haven't upgraded yet. Thanks again.
Message 12 of 17
(4,676 Views)
Message 13 of 17
(4,457 Views)
You are a genius. Thank you!
Message 14 of 17
(4,457 Views)
I am perhaps trying to do essentially the same thing. The latest version of LV that I have is 6.0 Could you recompile the example in 6.0 format for me so I can open it?
Kert
Message 15 of 17
(4,676 Views)
Oops,
Never mind. I just read further and see that you have already recompiled in 6.0 format. Thanks Much!
Kert
Message 16 of 17
(4,676 Views)
To those interested,
Attached is an example of the conversion from a double float to a 64 bit integer based on the bitwise definition of a double float in a big endian evironment (LabView under Windows i386). This incorperates some of the suggestions made by others herin. It is typically what you would write in C or assembly.
The library contains three vis, two conversion vis, and a test vi to insure the conversions work properly.
I'm not sure what the bit pattern will be in a small endian environment so I cannot provide the equivalent example. However, if you take the time to understand the example code provided, converting to small endian should not be difficult.
Kind regards,
Eric
Message 17 of 17
(4,457 Views)
