When a program included a CIN is executed,it always indicate that some memory can not be read or written,please why?
When a labview program included a CIN is executed,it indicates that some memory can not be read or written,then shuts down my program.My system is Windows 2000, please why?
(3,197 Views)
Assuming that this happens predictably, place a breakpoint inside the
CIN code and step line to line. The CIN is dereferencing an invalid
pointer. A common causes is that a string or array passed into the CIN
isn't sized as expected. C code is sometimes written to take in a
buffer that is presized. The DLL or CIN node doesn't know anything
about this size, so you need to presize it using the initialize array or
using a constant.
Greg McKaskle
(3,197 Views)
Because protected mode operation.
Read wrong address or write wrong address.
This is used to occur handle processing or pointer processing.
Pascal string, Array Handle / C string pointer.
Please check handle size, create, init and dispose.
In Pointer -> Initialize the pointer and data size check.
(3,197 Views)
