Convert dnp3 protocol to modbus
Hi all,
I am now having my slave device, which is a SEL 651 proctive relay, talking to computer through DNP3 Ethernet. I have a master model in LabVIEW to see the voltage and frequency transmitted back from the relay.
But right now I want to realize this over Modbus TCP. I have following confusion:
1. I didn't find a Modbus driver, only download a Modbus library from NI website. I am very confused how to replace those main DNP subVIs with Modbus subVIs. Any instrution or hint to guide me would be very appreciated.
2. For the first step, I only 'read' information. How shoud I know which register or coil, i.e. the address of the register and coil, that store the value of voltage and frequency that I want to read from slave SEL 651?
Attached is the code for DNP protocol. Any help is very appreciated!
(4,184 Views)
Accepted by jli63
You can try to get started to understand how the modbus library is used by checking the examples from the LabVIEW example finder. Specifically:
Modbus library.lvproj
Redundant Modbus Masters.lvproj
Here is also some documentation that I hope it can help:
Modbus Overview
http://home.hit.no/~hansha/documents/industrial_it/resources/resources/modbus/Modbus%20Overview.pdf
Daniel C.
(4,153 Views)
