Convert an 8-bit grayscale image into an RGB image
You can't.  When you convert color to gray, you lost the color info. forever.  Color plane is not enough.
You can convert the grayscale image to color image format.  But the image still looks gray to human eye.
George Zou
Message 11 of 14
(833 Views)
how about to transform the color images RGB to Y Cb Cr , process Y , and then re-transform the processed Y together with the un-processed Cb Cr
could that work?
https://en.wikipedia.org/wiki/YCbCr
Spoiler
Message 12 of 14
(823 Views)
could that work?
Spoiler
That might be a good idea.
George Zou
Message 13 of 14
(813 Views)
Perhaps just separate the original image into separate R, G, B components, then perform the de-hazing separately on each of them.  Then put them back together.
Message 14 of 14
(789 Views)
