Convert a string array 2d into a string
 Good afternoon. I need to convert a string array 2d into a string separating as per the image in the attachment. Can anybody help me?
String 2DString 2DString that I needString that I need
Message 1 of 8
(4,351 Views)
Accepted by topic author rafael.assis16
This might work. (FOR loop, index array concatenate string, array to spreadsheet string, trim whitespace)
Message 2 of 8
(4,347 Views)
Without loops
FYI CA's solution is probably faster, did not check, but it always is. 🙂
mcduff
Message 3 of 8
(4,340 Views)
Simple solution, I was trying to do something but did not think that way.
Message 4 of 8
(4,339 Views)
One more R-G way.
Message 5 of 8
(4,334 Views)
Be very careful with the other solutions presented. Some might blow up if e.g. one of the elements in the original string contains spaces, linefeeds, etc.). My solution retains all strings verbatim and is thus probably safer.
Message 6 of 8
(4,314 Views)
@mcduff wrote:
Without loops
mcduff
Without user defined loops. Under the hood those primitives are still looping.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 7 of 8
(4,309 Views)
Last solution had a bug, should be string length minus 3 NOT 3 minus string length
Spaces should be okay, carriage returns okay, linefeeds okay, BUT the carriage return line feed combo (\r\n) if contained in the original string then you will have some problems.
mcduff
Message 8 of 8
(4,291 Views)
