Convert a string array 2d into a string
 Good afternoon. I need to convert a string array 2d into a string separating as per the image in the attachment. Can anybody help me?
String 2DString 2DString that I needString that I need
Message 1 of 8
(4,720 Views)
Accepted by rafael.assis16
This might work. (FOR loop, index array concatenate string, array to spreadsheet string, trim whitespace)
Message 2 of 8
(4,716 Views)
Without loops
FYI CA's solution is probably faster, did not check, but it always is. 🙂
mcduff
Message 3 of 8
(4,709 Views)
Simple solution, I was trying to do something but did not think that way.
Message 4 of 8
(4,708 Views)
One more R-G way.
Message 5 of 8
(4,703 Views)
Be very careful with the other solutions presented. Some might blow up if e.g. one of the elements in the original string contains spaces, linefeeds, etc.). My solution retains all strings verbatim and is thus probably safer.
Message 6 of 8
(4,683 Views)
@mcduff wrote:
Without loops
mcduff
Without user defined loops. Under the hood those primitives are still looping.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 7 of 8
(4,678 Views)
Last solution had a bug, should be string length minus 3 NOT 3 minus string length
Spaces should be okay, carriage returns okay, linefeeds okay, BUT the carriage return line feed combo (\r\n) if contained in the original string then you will have some problems.
mcduff
Message 8 of 8
(4,660 Views)
