08-03-2007 05:28 PM
08-06-2007 08:16 AM - edited 08-06-2007 08:16 AM
A couple of things:
1. Do you really think that given the chance I would turn down the chance upgrade to the full version, have a service contract, and stay current with every new upgraded version? I wouldn't.
2. Do you think that I like having to write these hideously complex VI's with no real LV training whatsoever? I don't. I hate being in this position of filling some LV programmers shoes just because im the only one smart enough o figure out how to do it.
The first VI I provided had all sorts of buttons I was trying to connect with wires. That is the extent of my knowledge. I Didn't know what an event structure was, or how to use it, and I didn't know it was not in the base package, and that it would be so troublesome to work with. I very much appreciate you guys helping me out, but now im left with a VI that doesn't work, and now I am not capable of fixing it.
Dennis, Im not sure what happened when you graciously fixed the VI for the last time, but now It does not work anymore. I am unable to press the speed, estop, or stop buttons and the VI locks up after the second read function, (after I send the ACK 06).
I would like to eliminate the very cool, but unworkable-for-me event structure. It is just way over my head.
I think that the work that you people have done for me is spectacular. The scope of LV knowledege that is available thru this discussion board is amazing. To be honest LV really interests me. I like using it. However I do wonder how users such as Dennis become so knowledgeable about it. Have you gone to all the LV classes? Or are you learning it all from books or actual experience?
I would love to work for a large company that has the resources available to keep me up to date with all the LV updates, and I would love to go to all the training seminars. As it stands right now I haven't seen a raise in 2 years, and im stuck swapping hardware around from machine to machine to get the testing done. Some things are just beyond my control.
If there are some fantastic 3rd party LV books out there, I would certainly just go out and buy them for myself. Please let me know if anything like that exists.
Message Edited by Vr6Fidelity on 08-06-2007 08:32 AM
08-06-2007 09:09 AM
08-06-2007 09:43 AM
I think the last VI you got was from Ravens Fan but if it's broken now, you should attach your latest.
In order to eliminate the event structure, you have to use a polling technique. There are a couple shipping examples that show how to do this. One is called Old Event Handler. This uses an architecture called a state machine. You can compare this example to the one called New Event Handler. You don't have to use a state machine though. A while loop with your different front panel Booleans wired to case statements might be good enough.
I can sympathize with your situation. I was stuck with LabVIEW 7.1 for years and the only reason I was able to use that is because a department was closed down and I inherited the license. After years of begging, I came under new management and she was finally able to get me up-to-date and on support again. You just need to keep management aware of your needs and not give up. In the mean time, study the shipping examples and look through the example code on the Developer Zone. Also, log into the forum on a regular basis and look at other questions and answers - not just your own. I'm going through some old posts myself, to try to get up to speed on new 8.x features such as Xnodes and object oriented LabVIEW.
I can't really recomend any of the current books since I haven't purchased any of them. I had one of Gary Johnson's advanced LabVIEW books and thought it was excellent. Gary has been using LabVIEW since version 1.0. The book LabVIEW for Everyone is by Jeffrey Travis and Jim Kring. Jeffrey wrote an earlier book on Internet applications that I used and Jim Kring is regular contributor to this forum (and to OpenG).
08-06-2007 10:43 AM
Good morning Dennis. I hope you had a fabulous weekend.
Here is The Vi as it sits now. Im not sure how much sucess you will have running it, I know It returns NAN for all values on my office computer with no card, and since the code itself is depentant on answers from the controller, that dosen't really work well either.
Right now im trying to figure out why i have one more column of data than i do column headers! But I can handle those minor issues.
What I cannot comprehend is why some of the buttons cannot be pressed when the VI is running, which is not safe for humans around this ultra high speed experimental equipment.
08-06-2007 11:11 AM
@Vr6Fidelity wrote:
What I cannot comprehend is why some of the buttons cannot be pressed when the VI is running, ...
You need to learn to be much more specific when reporting problems. Which buttons can be operated? Which cannot?
One possible problems is that your event structure is configured to lock the front panel until it completes. If e.g. your VISA stuff has a long timeout, your FP locks for a long time. I thought you're going to eliminate the event structure?
08-06-2007 11:47 AM - edited 08-06-2007 11:47 AM
Message Edited by Dennis Knutson on 08-06-2007 10:48 AM
08-21-2007 08:49 AM
Ok Dennis I have moved onto my next LV task. But I am trying to improve my skills so this time I want to use the nifty for loop.
So in this super code you have given me, you have a for loop. So i read the help for the for loop and it talks of the N terminal for the number of iterations (channels in this instance). So to measure 6 channels I would wire 6 to the N terminal.
Here is where I get confused:
You have nothing wired to the N terminal. How does your for loop know what to do?
Also, You are not using index array at all. Instead you are using "convert from dynamic Data" which has a much longer and more complicated help file. Im not quite "getting it". I recently realized its a sub-VI, and I clicked on it. You have 1-D array of waveform selected. From my limited LV knowledge, I would imagine this would be an array consisting of ONE value from each scanned virtual channel coming out of the DAQ assistant. But then If this is true, I dont understand the use of "Get Waveform Components" from what I understand takes a waveform (a data type I dont quite understand) and breaks it into an array of y components at some unknown-to-me interval. Then The mean does its thing. I understand the mean at least!
So could you explain the functionality of the convert to dynamic data, and get waveform components combination? Why would you use these and NOT index array.
What would be the advantage of doing that vs a for loop with an index array instead?
I am interested in improving my coding skills, And most of my code seems to be almost offensive to you, so im anxious to improve.
Sincerely,
Grasshopper.
08-21-2007 09:02 AM
