Convert TDMS to TXT
I am trying to convert a TDMS file to a TXT file.  I want:
1. Convert Data Set (File) properties
2. Convert Channel Group properties
3.. Convert all the data.
The TDMS file "sc1616.tdms" is attached below. The attached "Convert TDMS.vi" can only convert one group data. I want to convert all the data. The TXT file will be like the attached "sc1616.txt".
Any help will be appreciated.
Steve
(11,820 Views)
First of all, I would have both the TDMS file and TXT file open until completion.  Then you complete each of your tasks one at a time.  First read the file properties and write those to the text file.  Use the TDMS List Contents to get the names of the groups.  Then you make a FOR loop with autoindexing the group names.  Inside of the FOR loop you get the group properties and write then to the text file and read the data and write those to the text file (much like you already have).
If you take it one step at a time, it will be a lot simpler.
(11,807 Views)
Thank you very much. I made it almost work. But there is one more problems. The data order I wanted in the text file (See the attached text file) is :
File Properties
Group Properties
Group Data
Group Properties
Group Data
Group Properties
Group Data
But now in the text file is:
File Properties
All Group Properties
All Group data
Steve
(11,756 Views)
Accepted by topic author Shijie
Sorry I attached wrong files in previous reply. The attached files here is the correct files.
Steve
(11,741 Views)
Are the text files that you are attaching the files that you are getting as a result of the conversion or are the text files what you are wanting to get/expecting?
Ian M.
(11,702 Views)
The attached text file is what I want to get. The problem has been solved.
(11,689 Views)
