Convert TDMS to EXCEL Error
What if I don't want to setup M.S Office to my computer? I don't use M.S. office and I didn't setup M.S Office on my workstation but I still want to convert this files TDMS to EXCEL. Do I have to setup M.S. office if I use this conversion?
Yasemin Barutçu
Electrical And Electronics Engineer
Message 11 of 15
(959 Views)
The VI you refer to directy uses MS Excel through its COM interface, and within MS Excel the NI TDM Excel Add-In to read TDMS files. So if you do not want to setup MS Office on you computer, you will have find another solution that does not require MS Office.
Message 12 of 15
(950 Views)
Hi No_RegreTs,
The trouble is creating the Microsoft binary *.xls or *.xlsx file, which LabVIEW doesn't do natively.  If you don't want to rely on Microsoft Excel to write the resulting Excel file, would it be sufficient to create a tab-delimited ASCII file that loads into Excel?  Many customer do this and then name the tab-delimited ASCII file with a *.xls file extension so that double-clicking on it loads the file into Excel automatically (albeit slower than a "real" *.xls" file).  LabVIEW does have a "Write To SpreadSheet File.vi" that would create a tab-delimited ASCII file.
Brad Turpin
DIAdem  Product Support Engineer
Message 13 of 15
(944 Views)
Thank you very much.. I'll try to do it using spreadsheet subvi.
Yasemin Barutçu
Message 14 of 15
(926 Views)
Not that I've ever used it, but there is a TDMS addin for OpenOffice as well.
http://zone.ni.com/devzone/cda/tut/p/id/6849
No idea how difficult it would be to perform the same operations with OpenOffice.
Message 15 of 15
(918 Views)
