Convert String to Decimal for Zigbee on NCD board
Thank you for your response. I am having trouble understanding what is posted however. I am finally able to get an output from the R Visa, but it only returns "U". So I was wondering what is within the case structure labeled "12 bit"? It seems like a lot is going on there, but I would like to be able to see what the outputs are in Dec or number format.
Thank you.
Message 11 of 15
(655 Views)
Yes, and the ascii code for an upper-case U in decimal is (drum roll please): 85!
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 12 of 15
(652 Views)
Capital U is an 85 (you really should keep an ASCII Table near by at all times).  Did you change the string to a byte array?  From there, Jeff was combining bytes to get larger data types based on the manufacturer's command structure for a 12bit acquisition.
Message 13 of 15
(651 Views)
Thank you Everyone!!!
Message 14 of 15
(643 Views)
Mike...
Not bad for coding from spec!Smiley Very Happy
"Should be" isn't "Is" -Jay
Message 15 of 15
(639 Views)
