Replacing simulate signal VI with DAQ assistant
I have a fucntioning VI, where in signal is coming in from 2 simulate signals VI and is being recorded.
I replaced this with the DAQ assistant. I want to know if, the wiring is correct and if it'll give me the same result as the simulated VI.
Thank you.
(3,290 Views)
The DAQ assistant is configured with 2 channels that acquire volatges.
(3,288 Views)
Greetings Lana89
I looked over your code. If you use the Dynamic Data type wire in the charts like in your simulated data code, you get the exact same functionality in both VIs.
Warm Regards,
Luis J.
(3,249 Views)
Accepted by topic author spatan2
Hello Tortu,
Thank you for the reply, yes I did do that as well, another way to do it is use the "split signal VI" this automatically splits the signal into 2 channels, the top most wire being Ch 0
S
(3,236 Views)
