Convert Floating Point Decimal to Hex
In my application I make some calculations using floating point format DBL,and need to write these values to a file in IEEE 754 Floating Point Hex format. Is there any way to do this using LabVIEW?
(6,869 Views)
To convert from DBL to Hex, have you tried the "Number to Hexadecimal String" VI In the String > String/Number Conversion palette?
(6,869 Views)
This is a great way of do it as long as one is dealing with integers. If that is not the case I do not think there is a short-cut soloution in LabVIEW. /Mikael
(6,869 Views)
Another thing to try is type casting. This can be found under Functions> Advanced> Data Manipulation> Type Cast on the block diagram. Type casting works for many other types of conversions as well.
(6,869 Views)
Mike,
Good news. LabVIEW has a function that does exactly what you want. It is well hidden though...
In the Advanced/Data manipulation palette there is a function called Flatten to String. If you feed this funtion with your DBL precision digital value you get the IEEE-754 hexadecimal floating point representation (64 bit) at the data string terminal (as a text string).
I attached a simple example that shows how it works.
Hope this helps. /Mikael Garcia
(6,869 Views)
