Convert 2013 to 2009
Hi everyone. I'm trying to save a .vi in a previous version, from LabVIEW 2013 to 2010, but it says there's an error and displays the message I'm showing in the attachment.  I have discovered that the block that is causing the trouble is one called "Display Message to User Express VI". You can find it in functions/programming/Dialog and User Interface/Display Msg. With all this said, the question is... Can my .vi be converted to a previous version without having to replace the "Display Message" block for any equivalent block from a previous version?
Im sending the Pruebafinal.vi  (the master vi) inside asdf.zip so if it can be done, you could help me out and convert it for me.
Thank you.
(2,722 Views)
Accepted by SEMA123
I get an error when I try to open that express VI on your diagram.  Personally, I would replace it with a case structure and the 1 Button Dialog function inside.
(2,719 Views)
