Convert 1D array a combobox
I wondered if it's possible to convert a 1D array of VISA Resource Names (COM Ports) and convert them to Strings then input these into a combobox? I'm hung up on the first part.
Message 1 of 9
(5,263 Views)
Hello
the solution is
Regard's
EricC
Ingénieur d'Application / Développeur LabVIEW Certifié (CLD)
Application Engineer / LabVIEW Certified Developer (CLD)
Message 2 of 9
(5,255 Views)
Accepted by Eric1977
Please see attached !
Best,
J.
Message 3 of 9
(5,252 Views)
What is the function your using to convert the VISA to a string?
Message 4 of 9
(5,251 Views)
The function is "Type Cast".
It is located in Numeric > Data Manipulation palette.
Message 5 of 9
(5,248 Views)
Why do you use "type cast" to convert visa to string ?.
it is a complexe way to do the job !!!!
Regard's
EricC
Message 6 of 9
(5,240 Views)
You're right : "Concatenate Strings" function is much better.
Best,
J.
Message 7 of 9
(5,235 Views)
Of course a more general solution can make use of a vi server referance to the combo box and the Configuration API functions.  Here is an example.
Since we don't often see examples using this API I thought it would be a good Idea to show how powerful this can be for programatically determining what is connected.  That sys hw Property node has some awefully interesting properties in it that can be explored.
"Should be" isn't "Is" -Jay
Message 8 of 9
(5,225 Views)
OK, I have one other question.
When I use the code below, I return COM1, COM3, and LPT1. On another computer, I return ARSL1::INSTR, ASRL2::INSTR, and ASRL10::INSTR. What gives? Do I need to update teh VISA Runtime? If so, what is the latest version?
I'm rinning 2010 SP1.
Message 9 of 9
(5,183 Views)
