Conversion
How can we convert a program written in labview 6.1 to program readable in labview 11?
(3,186 Views)
Accepted by POST
You can ask for a conversion in the Version conversion Board along with the file.
(3,184 Views)
I think you dont need a conversion. Higher version will automitically read the older version.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
(3,181 Views)
No. It is upto some versions only if that is below then you need an upconversio to read them in higher versions
(3,176 Views)
thanks a lot for ur help . .keep in touch
(3,167 Views)
LV2011 can open VIs from all the way back to 6.0.  See here for the complete rundown: http://www.ni.com/white-paper/8387/en
(3,149 Views)
