Conversion to Base 36
I am working on a serial number code converter which stores 5 digit serial numbers as 3 digit alphanumerical codes. For this project I need a way of creating an array of base 36 numbers, however I cannot find a way to convert decimal numbers to base 36 strings in Labview.
Does anyone know of a simple way to do such a conversion? Any help would be much appreciated.
My organisation is only running Labview 2014, so any VIs need to be compatible with that, thanks.
Message 1 of 11
(7,297 Views)
I had never heard of base36 until now.  If your serial number is only 5 decimal digits, why would you even need to convert to a 3 digit base-36 number?  It doesn't seem to give you much advantage is saving space.
I think it is so uncommon that it is unlikely you will find anyone with ready-made VI's.
I think you'll just need to google some algorithms and code them yourself in LabVIEW.  I imagine that you will need a look-up table of some sort to convert the letters to their decimal equivalent.  And the Quotient Remainder Function will likely come in handy.
Message 2 of 11
(7,274 Views)
Message 3 of 11
(7,273 Views)
Thanks for the response.
Unfortunately the base 36 code has been chosen by our customer; it certainly provides a challenge for me as I'm still fairly new to LabVIEW.
I have found a perfect VI that converts from base36 to decimal, post linked below. Is there an easy way to reverse engineer this to work backwards?
https://forums.ni.com/t5/LabVIEW/CONVERT-BASE-36-TO-DECIMAL/m-p/728370/highlight/true#M333385
Message 4 of 11
(7,268 Views)
Hi mars,
Yes.
It involves some Quotient&Remainder functions and a simple conversion (using a LUT/look-up table) to convert the base36 values into readable chars.
It's a nice project to actually learn some LabVIEW basics, like loops with shift registers and autoindexing, array handling, …
Message 5 of 11
(7,259 Views)
If you want to learn to code in LabVIEW, take this as an opportunity to figure it out on your own.  The Wikipedia article has a C implementation.  Use this as a guide.
aputman
Message 6 of 11
(7,251 Views)
Accepted by topic author mmarsden23
I'd rather use the Altenbach-version....
Message 7 of 11
(7,209 Views)
That version does seem a little cleaner. I'm not sure how a matrix just full of 256 0's can be considered a lookup table, however. What is being "looked up", just the index position?
I'm not sure my coding ability is able to reverse engineer this one, even though I know the theory behind for loops etc, I don't think I'm ingenious enough to figure this stuff out yet.
Message 8 of 11
(7,158 Views)
Many thanks for posting that version Alex. I've managed to adapt it into converting my 1D array.
Message 9 of 11
(7,152 Views)
he posted a previous version, which is easier to read :
base36StringToDecimalString.vi ‏10 KB
 it's not completely filled with 0 - there are 35  non-zero values
what do you think do  these numbers represent?
Smiley Wink
there's also a reason, why there are 256 elements in the LUT
you may also want to read the quite short help for the "string to byte array" function
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/functions/string-to-byte-array.html
Message 10 of 11
(7,143 Views)
