Conversion from Excel time to labview time
Hello all,
                                   I want to convert the excel time stamp to labview time stamp. Can you all please help me how to do this ?
In my application labview time is 05-11-12 14:56:00 and its equivalent excel time representation is 41218.6222222222.
I tried this formula,
Labview time =  24*3600*(Excel time - 1460) but anwer is wrong.
Thanks.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 1 of 21
(4,919 Views)
Did you search first?
PaulG.
Retired
Message 2 of 21
(4,896 Views)
Ok, here's what I found.  The conversion is:  Time Stamp = 86400*(Excel Time - 1462).  But here's the kicker: the timestamp is GMT.  You have to add your time zone offset as well.  I'm in the Eastern Time Zone, so I had to add 5 hours.  I'm not sure what DST will do to this.  I'm sure there's ways around it, I just don't have time to look into it more right now.
Message 3 of 21
(4,895 Views)
Hi crossrulz,
                                     This logic is not working, Please try the number what i provided in the question.
Thanks.
--Ranjeet
Message 4 of 21
(4,871 Views)
Hi all,
                            What i found is that when representing the time into excel sheet. the difference between time is not constant
#1. 14:51:00 11-05-2012    ------   41218.61875
#2. 14:52:00 11-05-2012    ------   41218.6194444444
#3. 14:53:00 11-05-2012    ------   41218.6201388889
#4. 14:54:00 11-05-2012    ------   41218.6208333333
#5. 14:55:00 11-05-2012    ------   41218.6215277778
#6. 14:56:00 11-05-2012    ------   41218.6222222222
So if the difference between the numbers is not same than we cannot find any common logic for conversion.
Agree friends ?
--Ranjeet
Message 5 of 21
(4,867 Views)
There are some slight rounding issues, but the results are fine for me...
NOTE: My date is setup as M/D/Y
Message 6 of 21
(4,855 Views)
Its look like that i am committing some mistake. I also tried this but my answer is wrong. Can you please tell me why ?
One more thing how exactly you got this 1462, i think this should be 1460 ?
--Ranjeet
Message 7 of 21
(4,837 Views)
What time zone are you in? Can you attach the actual VI?
I put "1/1/1904 0:0:0" into and cell in Excel and then performed a value() on that cell.  The result was 1462.
Message 8 of 21
(4,820 Views)
Excel has two errors related to its data calculations.
1.  Day 0 is Jan 0, 1900.  Which of course doesn't exist.  Jan 1, 1900 is day 1 in Excel. (There is a 1 day error.)
2.  Excel thinks that Feb. 29, 1900 exists as a leap day, while in reality it doesn't.  (So there is another 1 day error.)
Day 0 is Jan 1, 1904 GMT in LabVIEW .  And since it doesn't have the year 1900, the presence of a leap day in 1900 or the lack thereof doesn't show up in LabVIEW's data calculations.
Message 9 of 21
(4,810 Views)
another one.
Time to XL can be downloaded from here https://decibel.ni.com/content/docs/DOC-19689
as well as it's inverse XL to Time
Significantly Excel epoch is dependant on the OS system time zone (Yes, it is insane 0 means midnight on the 0th of January 1900 local time) and there is the famous leapyear bug Microsoft copied fron Lotus)
Don't forget to vote
"Should be" isn't "Is" -Jay
Message 10 of 21
(4,803 Views)
