Controlling two relays
I have a problem in controlling the relays i developed to two loops for relays one to control solenoid and other to control fans. solenoid loop should be working when fans stops. I am unable to control the loops or may be my developed logic is incorrect. Please any body help me with this. I am using pxi2586 hardware.
thanks
shaik
Message 1 of 15
(4,383 Views)
can you pls down convert it to 8.6 and post or just post block diagram code, this might help me
Message 2 of 15
(4,365 Views)
Hello systemcrash,
I am new to labview i dont know how to convert from labview 2010 to labview 8.6...
Message 3 of 15
(4,361 Views)
@shaik1 wrote:
Hello systemcrash,
This is documented in the LabVIEW Help. File -> Save for Previous Version.
Message 4 of 15
(4,356 Views)
Hi
please see the attachment for the down converted version.
Regards
shaik
Message 5 of 15
(4,348 Views)
Two loops are independent of each other and hence you cannot control.
I haven't worked with Ni-Switch but you are initializing at 2 different places and you are using same credentials even though you use different control K0&K1 is it not giving you error ?
One simple thing you can do is Use FAN CONTROL local variable in SOLENOID LOOP. When FAN CONTROL becomes true start the solenoid functionality.
Controlling can be done in many ways, try the above method as initial try.
See the attached Modified VI.
Kudos are appreciated.:manvery-happy:
Message 6 of 15
(4,339 Views)
HI,
The reason I am using different initialzation is I want the solenoid to switch ON and OFF as soon as the fans stop and again switch ON and OFF before the fans starts again.  Attatched is a signal diagram for the fans and solenoid functioning.
Regards
shaik
Message 7 of 15
(4,314 Views)
did you try that attached modified VI. The same initialization will do the task you mentioned. You dont need 2 different initialization.
Message 8 of 15
(4,297 Views)
HI,
I did tried but its only initializing fans relay not the solenoid relay.
Regards
shaik
Message 9 of 15
(4,281 Views)
ok, pls try same concept with 2 different initialization then . And your application is solenoid should turn on when your fan control is stopped write?
Message 10 of 15
(4,279 Views)
