Controlling Maxon motor with LabVIEW over USB
I'm creating and answering this for progeny. It looks like I had an issue that a lot of people have unsuccessfully shared.
problem
I have a Maxon 24/5 motor that I can control with EPOS Studio via USB, the control suite developed by Maxon. Now, I wish to control the motor via LabVIEW. How do I do this?
(7,684 Views)
Accepted by aeroAggie
solution
Assuming you already have the motor drivers (for Windows):
1. Download the LabVIEW instrument driver EPOS 2 from NI
2. Extract the drivers to your LabVIEW installation's instr.lib folder. For me, that folder is here:
C:\Program Files (x86)\National Instruments\LabVIEW 2016\instr.lib
3. Open a new VI in LabVIEW, right click in the block diagram, and navigate to the EPOS sub-sub-pallette in the instruments sub-pallette. Make sure that you do not have the EPOS P drivers. Those are separate and apparently useless.
4. Load one of the examples, and set the "communication settings in" values as follows:
deviceName: EPOS2
protocolStackName: EPOS2_USB
interfaceName: USB
portName: USB0
baudrate: 1M
timeout: 500
5. Set your desired position/velocity, and press start!
I just figured this out myself, so I'm going to tackle how to actually program the controller next. I'm just glad I finally figured out how to connect to the darn thing.
Thanks to Prasanth_Thangavel for his initialization pic here, and JB for indirectly guiding me there.
(7,675 Views)
Is this library compatible with EPOS 4 systems?
(7,278 Views)
You should compare the specs from the EPOS2 and EPOS4.
(7,268 Views)
Try it! The worst that will happen is it won't work.
(7,220 Views)
