Controlling Cursor - Plot order
Hi Jason:
Got back to this with unsuccessful results.  The code attachment shows what I tried to do immediately after plotting the new window (the plot window boolean event case).  The code underlap, as opposed to the code overlap, shows the effect I am after.
Don
Message 11 of 13
(936 Views)
Hi, Don. I got around to working on that VI and have attached it here. It seems to work as you described.  I haven't commented it, so let me know if you have any questions about why things are implemented a certain way.
It does seem that the cursor position info for the Cursor Move event is bogus, but I didn't look into it much. I'd avoid using that and  use a property node instead whenever you want to get the X,Y position of a cursor.
J
Jason King
LabVIEW R&D
Message 12 of 13
(908 Views)
Hi Jason:
Yes, you have fixed it and got it working as I would like.  I'm going to study the code to see what you did.  Thanks for taking the time!
Sincerely,
Don
Message 13 of 13
(897 Views)
