Controling channel separation from waveform array parametricaly?
Hi.
I have an application where I aquire both Strain & Temperature. The number of sensors of each type varies from test to test. I'd like to graph each type on differents graphs so that I can scale them properly. I attach an image of my application.
Is there any way to control it via front panel?
Say, using a numeric control to define the numbers of Strain gages (first N channels are strain gages, rest thermocouples), and then separate the data.
Usuario
(2,880 Views)
Accepted by topic author usuario
Hi Usuario,
you can use the split array function.
Mike
(2,874 Views)
