Control of two DC motors to simulate a plotter
I'm making a program with two DC motors.
I want to enter a word in Labview and the engines write that word (moving them into X, Y).
I know what position the engine is from labview, but I don't know how i can do that the program read one letter or word.
I have Labview 2011
2x Epos2 P 24/5 conected by USB
Motor Maxon DC RE 30 ∅30 mm, Graphite Brushes, 60 Watt
Motor Maxon DC RE 40 ∅40 mm, Graphite Brushes, 150 Watt
2x Encoder MR, Type L, 256 - 1024 CPT, 3 Channels, with Line Driver
(3,406 Views)
I guess I'd make a library of motor movements that correspond to ASCII characters written as motor offsets, not hard values.  Can you take it from there?
Bill
CLD
(Mid-Level minion.)
(3,394 Views)
How can I make the library? with Labview or other program? Have to be .dll?
and how can i do the program read a letter?
I'm a little lost
(3,368 Views)
I have already a file which read letters and convert them on numbers. Now I need to call each file of the library depending with the motor movements.
any help?
(3,336 Views)
any help?
I think you are on the right track!  You can parse the array with an auto-indexed for loop call your library of movements based on the value of the array element.
Bill
CLD
(Mid-Level minion.)
(3,319 Views)
