Control number of digits using format function
Please, I am trying to control the number of digits using format function and Format Specifier.
I acquired data using data acquisition. I got a number such as 1654.1876872. I want to get only two digits after comma such as 1654.18
I attached sample of the Vi which I tried but it's not working correctly
(3,359 Views)
Try "%.02f" for the format string.
(3,337 Views)
Thank you for your reply. Please, I tried it but its still not working
I attached the Vi
(3,327 Views)
Accepted by topic author Ke_Zank
Read the detailed help for that function.  You have nothing wired into value.  Your "value" is a string you wired into the prepend string input.  If your "value" is a string, you need to convert it to a number and back to a string.
Format Into String is much more commonly used than Format into Value.  For one, it lets you format multiple values into a single string if you need to.
(3,320 Views)
