Control increment button repeat rate
I'm working on an application in which the user must be able to change the value of multiple numeric controls using a touch screen interface.  The touchpanel I'm using generates normal mouse events so its essentially like interacting with the front panel only using a mouse.  Each numeric control has large increment/decrement buttons next to it to click/touch on.
The question I have: is it possible to control the speed at which the numeric controls increment programatically?  I invision it to start at a slow speed increment repeat rate then after a few seconds of continuous mouse down go to fast speed increment repeat rate.
It seems that the controls increment at a constant speed reguardless of being in loops with different mS-wait times and even when not in a loop at all.  I have also seen the shift+click trick to increase the increment speed, but this system in its final form will not have a keyboard.  Perhaps the shift+click can be emulated programatically.
Any help is appreciated,
Eric Hoffman.
Eric Hoffman
LV 8.20 FDS on Windows
(4,404 Views)
Hi Eric,
what you could do is make new controls (up and down), and wait for a mouse-down event. Then you start the count up in a seperate while loop (queues or notifiers) then slowly speed up your rate, and terminate this while loop on a mouse-up event.
It would be really cool to have this in an XControl!
Ton
My LabVIEW Ideas
(4,386 Views)
Yeah I thought of that but I have 8 of these controls which would make for a lot of programming.  I was hoping for something a little more elegant.  Xcontrol does sound like the way to go unfortunately I do not have access to that package.
Eric Hoffman
(4,371 Views)
Here's my try,
you should put inside a subvi (reentrant) just like i did with the up_down.vi
Ton
My LabVIEW Ideas
(4,343 Views)
