Hello Turbot,
National Instruments strongly suggests using only one IP address. Your shared variables are breaking because they cannot connect to the IP address to which they were deployed.
Also, although the discussion forums are monitored by the applications engineering department, this forum was created so customers could contact each other. If you are looking to talk with support, you should go to
www.ni.com/ask but there is no need to address support in your forum post.
Have a fantastic weekend!
Janell R
